Camera Selection Help
New Camera Options
LightBurn 2.1 allows for a wider range of cameras to be used, including web-based IP cameras and a wider range of manufacturers' built-in cameras.
The Camera Selection Help window helps you select an appropriate camera for your laser. The information provided is specifically for the cameras sold on LightBurn's Website, which are known to work well with LightBurn and have calibration presets built into the software for easier Lens Calibration.
Go to HelpCamera Selection Help to open the window.
Can I Use a Camera I Already Have?
Possibly. Interactions between cameras and computers are complex, and although a wide range of cameras are compatible with LightBurn, we can't guarantee your camera will work. If you want to try using your own camera, your best option is a fixed-zoom USB camera that can be detected as a webcam by your computer.
Selecting a Camera
To select a camera, you'll need to know two things:
  1. The size of your laser's work area, in millimeters.
  2. The distance between the height from which you want to mount the camera and the surface of your laser's work area.
Diagram showing ideal mounting location
To select a camera:
  1. Enter the machine size into the Camera Selection Help window.
  2. Look through the list to find a camera with a minimum mounting height about 2 inches less than the height you intend to mount at. This leaves room for adjustment.
  3. Double-click an entry in the list to visit the product page to purchase it.
Some computers may cause complications with the use of cameras. In some cases – especially with newer computers such as M1 or newer Macs – this comes from incompatibilities between USB 3.0 ports and older USB 2.0 cameras. Try using a USB 2.0 hub or adapter between the camera and the computer.
See Camera Troubleshooting for more information.
