Use File → Print (Black Only) or File → Print (Keep Colors) to print the current contents of the work area using your computer's print dialog. Most computers have built-in PDF creation tools, allowing you to export a PDF using these tools as well.
Page Size Warning
Be aware that the page size is controlled by the print dialog, not by LightBurn. If your work area is larger than the paper selected for printing, your design will be scaled to fit on the paper.
Windows 10 print dialog showing options including sending to a printer and Print to PDF
If your design is printing too small, check the paper size you're printing on.
Beyond that, printing problems are likely to be related to your computer and/or printer, rather than LightBurn. Please see the relevant customer service resources for more help.
