Device Settings
The Device Settings window contains device-specific settings for your laser. The settings available change based on the device selected — not all settings described below will necessarily be shown in your instance of LightBurn.
Access Device Settings by selecting Edit → Device Settings or by clicking
in the Main Toolbar.
Device Settings Window¶
The Device Settings window is split into several tabs, not all of which will be available for all machines.
- If you aren't seeing a setting you expected to see, check which tab you're in and make sure it's applicable to your laser.
