Reset to Default Layout
Reset to Default Layout restores the layout of the full LightBurn window to the same format it was in when you first installed and opened LightBurn. If you've made lots of changes to your layout that you want to reverse all at once, or you've lost sight of the Laser Window, Cuts / Layers Window, Color Palette, or any other default windows or toolbars, use this option to get them back.
Resetting the layout doesn't reset anything else — your preferences, devices, and libraries are all preserved.
Go to Window → Reset to Default Layout to re-open and re-dock all default windows in their original order, while closing any that are not visible by default.
Holding Shift while clicking to open LightBurn will also reset the layout.
