Laser Window
The Laser Window is the hub for setting up and selecting a laser, Framing and Starting jobs, determining job positioning, and more.
Accessing the Laser Window¶
The Laser Window is located in the bottom right corner of LightBurn by default. If you have closed the Laser Window, go to Window → Laser to re-enable it. To restore it and all other windows to their default positions, go to Window → Reset to Default Layout.
Laser Window Options and Settings¶
The type of laser you have active, and certain options in the Settings window, including enabling Beginner Mode, will affect the way the Laser Window looks.
The above image shows the default layout of the Laser Window as it appears for a DSP laser. Some settings that are not available for DSP lasers, or are not enabled by default, are listed in the page below. Check this page's table of contents if you do not see the setting you're looking for in the image.
Start¶
Commands your laser to immediately begin running your current project.
If you have a Galvo laser, you'll see the Framing window first, unless you turn off Require framing before start in your Device Settings.
Pause and Stop from the keyboard
While your laser is running, you can use your keyboard's Pause key to Pause the laser and Ctrl+Break to Stop it. Break is typically on the same key as Pause, but more compact keyboards may not have this key.
Stop¶
Immediately aborts a currently running job.
Pause¶
Halts a running job. Click the Resume button to continue a paused job.
Send¶
The Send button, if your laser supports it, transfers the current job to the laser as a named file, so you can select and run it from the laser's controller.
When you use Start, the controller begins running the job as soon as sufficient data has reached the controller. Using Send instead of Start can sometimes help prevent file corruption during transfer.
Hold Shift while clicking Send to have the laser immediately start the job after the entire project has been sent.
The Send option is only available for DSP lasers.
Framing¶
Note for Galvo users
This section covers Framing behavior for Gantry lasers. If you have Galvo laser, see Galvo Framing.
Use the two Frame buttons to preview the position of the job in your laser's work area, by commanding the laser to trace a path around the area where your project will output.
The speed at which the laser travels during Framing is determined by the value set in the Speed field in the Move Window.
Frame Continuously¶
Enable Frame Continuously in the Basic Settings tab of Device Settings to command your laser to run the Framing path repeatedly, until you tell it to stop. Framing Continuously is often helpful when adjusting material positioning in your laser's work area.
Laser on When Framing¶
Enable Laser on when framing in the Device Settings window to Fire the laser during the Framing process, at the Power level set in the Move Window.
If Laser on when framing is not enabled, you can hold Shift while pressing Frame to enable the laser during the framing process.
Danger
This changes the default behavior of the laser and can cause the laser to fire when a user is not expecting it. Enable this setting with caution, with a very low power level, and only when using a diode laser.
Bounding Box Frame
Commands the laser to trace a path defined as the smallest possible rectangle that will fully contain all graphics you're sending to the laser.
Rubber Band Frame
Traces the smallest possible path that fully contains all graphics in the design you're sending to the laser, as if a rubber band were stretched around them.
Rubber Band Framing is useful for lining up jobs with irregular shapes where a box outline doesn't fit well. For example, a long, thin diagonal shape, or a triangle.
Save Machine Files¶
This button will change depending on the type of laser you're using — it may say Save GCode (for GRBL, Smoothieware, or Marlin controllers), Save RD File (Ruida), Save OUT File (TopWisdom), or Save UD5 File (Trocen).
All options save your current project as a machine-ready file, in the appropriate format for your type of laser. You can transfer this file to your machine to run it without ever having to directly connect using LightBurn.
These options are also available in the File Menu.
Run Machine Files¶
Use this option to load and run a file previously saved in the appropriate format for your type of laser. To use this option, LightBurn must be directly connected to your laser.
This button will change depending on the type of laser you're using — it may say Run GCode, Run RD File, Run OUT File, or Run UD5 File.
Home¶
For GCode lasers: Commands your laser to execute a homing cycle, during which it moves toward the home position looking for the switches that activate when it hits the boundary.
For DSP lasers: Moves the head of the laser to the machine origin.
Homing is how your laser locates its 0,0 position, and all subsequent positioning information is determined relative to that point.
Do not use this button if your laser does not have homing switches. If you are unsure, contact your laser's manufacturer.
Go to Origin¶
Commands your laser to jog to the position currently set as the User Origin.
See Coordinates and Job Origin for more information.
Start From and Job Origin¶
These two controls determine where the job is placed on the bed of your laser.
Cut Selected Graphics¶
This toggle switch tells LightBurn to only send the portion of your design that is currently selected when you click Start, Send, or Save Machine File.
See Cut Selected Graphics for more information.
Use Selection Origin¶
Only available in combination with Cut Selected Graphics, the Use Selection Origin button tells LightBurn to calculate origin relative to selected graphics only, and not the whole design.
See Cut Selected Graphics – Use Selection Origin for more information.
Show Last Position¶
Places a cross-hair cursor in the Workspace at the last reported location of the laser head. If you jog the laser within LightBurn using any of the positioning tools, the position will be updated.
The position does not update live — for example, it will not update while a job is running. Live updating might encourage some users to watch the screen rather than their laser — lasers should never be left unattended while running.
Enable Rotary¶
This switch controls whether Rotary Mode is enabled. When enabled, rotational commands are sent to the laser to control rotary motion.
In order to see this switch in the Laser Window, you must turn on Show rotary enable in main window in your Settings/Preferences.
Rotaries are used to turn cylindrical objects so that their surfaces can be marked by a laser. Before using your laser with a rotary, you must first establish several important parameters in the Rotary Setup window that control the rotary's motion.
See Rotary Mode for more information.
Enable Cylinder Correction¶
This setting is available for Galvo lasers only.
This switch controls whether Cylinder Correction is enabled. When enabled, LightBurn warps the output of your design to correct for distortion caused by engraving cylindrical objects, without using a rotary.
In order to see this switch in the Laser Window, you must turn on Show cylinder correction enable in main window in your Settings/Preferences.
Before using Cylinder Correction, you must first establish several important parameters in the Cylinder Correction Setup window that determine how LightBurn will warp your output.
See Cylinder Correction for more information.
Enable Red Light¶
This switch controls whether your laser's Red Dot light is enabled. In order to see this switch in the Laser Window, your laser's Red Dot light must be controlled by an IO Port, and the appropriate port must be set in your Device Settings.
Optimization Settings¶
This button opens the Optimization Settings window, where you can adjust various options that control the order in which your graphics are cut or engraved by the laser.
See Optimization Settings for more information.
Devices¶
Opens the Devices window, where you can create, remove, or edit device profiles for lasers you want to use with LightBurn.
Right-clicking the Devices button closes and re-opens the connection to the currently selected device.
See Devices for more information.
Device Selection Dropdown¶
If you've created multiple device profiles for multiple lasers, select the laser you are currently working with the dropdown menu.
Serial Port Dropdown¶
LightBurn will attempt to automatically select the correct serial port and connect to your laser, but you may need to manually select it from this dropdown. When connected, the Disconnected message in the top left corner of the Laser window will change to Ready. If you are using a GCode-based laser, you will see a startup message in the Console window.
You may need to right-click the Devices button in the Laser window to refresh the list of available ports.
If you're having trouble connecting to your laser, see Troubleshooting: Connection Problems.
Device Status¶
The readout in the top left of the Laser Window indicates the current status of the laser.
Disconnected indicates that the laser is not connected to LightBurn.
Ready indicates that the laser is connected to LightBurn and ready to receive commands.
Busy indicates that the laser is connected to LightBurn and actively completing a process.
The progress bar indicates the percentage of commands that have been streamed to the laser, along with a time estimate indicating how long the laser has been streaming, and how much longer it will continue streaming. These estimates can be close to the total runtime of the project, but are not identical.
Framing appears for Galvo lasers only, to indicate that the Framing process is active.
