Galvo Framing
Quick Reference: Galvo Framing
  • Hero Image
    Outlines projects in your laser's work area using a red dot light.
Framing is a function of Galvo lasers that outlines projects in your laser's work area using a red dot light, allowing you to see where your design will output on a physical object.
Click the Frame button in the Laser Window or press F1 to open the Live Framing window.
You may need to hold the Fn key while pressing F1 to open the Live Framing window.
By default, the Live Framing window will also open when you press the Start button in the Laser Window, but you can disable Require framing before start in your Device Settings.
The Live Framing window contains options that determine the style of framing, which graphics are framed, and how many times to repeat a given project.
You can Start, Stop, and Pause your projects from the Live Framing window, which remains open while your job is running.
While framing, you can nudge, rotate, and rescale graphics, adjusting them in your Workspace and live-updating them in your laser's work area.
Framing Styles
The different options determine how the red dot light represents your shapes, and which shapes are shown.
Press F1 while framing to cycle through the Bounds, Hull, and Contour framing modes.
Bounds
Commands the red dot light to trace a path defined as the smallest possible rectangle that will fully contain all graphics you're sending to the laser.
This mode is extremely fast, but doesn't represent complex shapes well.
Bounds framing example
Hull
Commands the red dot light to trace the smallest possible path that fully contains all graphics in the design you're sending to the laser, as if a rubber band were stretched around them.
It is nearly as fast as Bounds, but gives a much closer fit for rounded or smooth shapes.
Hull framing example
Contour
Commands the red dot light to trace a path that follows the exact contours of your shapes — it takes the longest to draw, but it's the most accurate.
Contour framing example
Additional Options
Frame Individually
Determines whether to trace a single Bounds or Hull frame around everything in your project, or around each individual shape.
This option is grayed out when using Contour framing.
Image Bounds
Attempts to quickly trace the outlines of any images you have in your design, rather than only showing the rectangular boundary of the entire image.
LightBurn determines the outline based on transparency and whitespace in the image — accuracy may vary.
Outside Shapes Only
Tells the software not to trace inner shapes, like the insides of letters — typically this doesn't affect placement, but allows a faster update of the frame (this only affects Contour mode).
Tool Layers Only
Tells LightBurn to only frame shapes that are on one of the Tool layers.
Job Control
Start
Commands your laser to immediately begin running your current project.
Stop
Immediately aborts a currently running job.
Pause
Halts a running job. Click the Resume button to continue a paused job.
Job Counter and Multiple Runs
Count
This value is incremented at the end of each successful run of your file. You can use this to keep track of how many parts you have marked, or how many passes of a single job you've run.
Reset Count
Resets the Count value to 0.
Run Continuously
Tells LightBurn to re-start the job automatically after it finishes, and update the Count after each run.
  • Turn the switch off while a job is running to stop the laser when the current run completes.
  • Press Stop to immediately halt the laser.
This is useful when you are doing very deep engraving, and are unsure how many passes a job will need.
Ensure your laser is properly supervised, even during long jobs with multiple passes.
Repeat
Enable this switch and set a value in the adjacent field to tell LightBurn to run the entire job the specified number of times, and then stop.
If you turn off this switch while a job is running, the laser will stop when the current run completes.
To run multiple passes of specific layers, sub-layers, or combined sequences of sub-layers, see the Number of Passes and Global Passes settings in the Cut Settings Editor.
Stop At
Enable this switch and set a value in the adjacent field to disable the Start button if the Count is greater than or equal to the specified Stop At value.
This option is especially useful when the job is externally triggered (e.g. with a foot switch), as LightBurn will ignore the external trigger once the Count reaches the Stop At value.
Nudging, Rotating, and Rescaling
While framing, you can use the keyboard to nudge, rotate, and rescale your graphics.
Key(s) Result
Left / Right / Up / Down Move graphics by 5 mm
Shift + arrow keys Move graphics by 20 mm
Ctrl + arrow keys Move graphics by .5 mm
Page Up Scale graphics up
Page Down Scale graphics down
. (period) Rotate graphics 15° clockwise
, (comma) Rotate graphics 15° counter-clockwise
Shift+. (period) Rotate graphics 1.5° clockwise
Shift+, (comma) Rotate graphics 1.5° counter-clockwise
Ctrl+. (period) Rotate graphics 45° clockwise
Ctrl+, (comma) Rotate graphics 45° counter-clockwise
If your keyboard doesn't have Page Up or Page Down, try using Fn+Up or Fn+Down.
  • If the framing location or scale is inaccurate, you may need to adjust your laser's focus, or fine-tune the values found in Device SettingsGalvo and Basic SettingsRed Dot.
    See our video guide for more information on adjusting red dot alignment.
  • If Contour framing doesn't work, try toggling off Enable Blanking Delay, in Device Settings, under IO Port Settings.
  • For information on framing behavior when using a rotary, see Rotary Mode (Galvo).
