File Management
Use the file management tools to start New projects, Save projects you're working on, Open previously saved projects, and Import or Export artwork in alternative file formats.
Most file management options are available in the Main Toolbar, with a few additional options available in the File Menu.
File Management options in the File Menu
File Management options in Main Toolbar
New
Ctrl/Cmd+N
Clears your current LightBurn project and starts a new, blank project.
Opening a new project does not change any Settings, window customizations, and special modes active from the last opened project.
If you have an existing project open with unsaved changes, LightBurn will ask you if you'd like to Save before starting the new project, click No to discard the changes, or Cancel to abort the process.
New File warning
Open
Ctrl/Cmd+O
Opens a .lbrn or .lbrn2 project file previously stored on your computer.
If you have an existing project open with unsaved changes, LightBurn will ask you if you'd like to Save before Opening the project, click No to discard the changes, or Cancel to abort the process.
New File warning
If you have multiple device profiles, and the device you were using when you Saved the file is not currently selected, LightBurn will ask if you'd like to automatically switch to that device profile.
Click Yes to switch or No to open the file with your current device.
Switch profiles question
Click on the dropdown in your system's file browser to show all supported file types, including supported image and vector file types.
Selecting a supported image or vector file instead of a project file will create a new LightBurn project, replacing the currently loaded project. Use Import to bring artwork files or designs into an existing project.
Recent Projects
Hover over Recent Projects in the File Menu to open a submenu containing a list of projects you've recently worked on and Saved.
Click any file in the list to Open it.
Recent Projects Submenu
Save
Ctrl/Cmd+S
.lbrn and .lbrn2
The Save and Save As commands offer the option of saving as .lbrn2 (default) or .lbrn (LightBurn Legacy Project).
Unless you need to maintain compatibility with extremely old versions of LightBurn or need an easily human-readable file, we recommend leaving the file type set to .lbrn2.
Saves your current project in .lbrn or .lbrn2 format.
  • If you haven't Saved it previously, a dialog window will open where you can name it and choose the location to Save it.
  • If you have already Saved a copy, the existing copy will be immediately overwritten with any new changes you've made.
Save As
Ctrl/Cmd+Shift+S
Rather than immediately overwriting your existing file, Save As opens a dialog window where you can save a renamed copy to a new file, leaving the current file unchanged.
Save dialog
Save Machine File
This option will change depending on the type of laser you're using — it may say Save GCode (for GRBL, Smoothieware, or Marlin controllers), Save RD File (Ruida), Save OUT File (TopWisdom), or Save UD5 File (Trocen).
All options save your current project as a machine-ready file, in the appropriate format for your type of laser. You can transfer this file to your machine to run it without ever having to directly connect using LightBurn.
See Laser Window — Save Machine Files for more information.
Import
Ctrl/Cmd+I
Loads graphics from a variety of file formats into LightBurn. Click on the dropdown in your system's file browser to filter for supported image and vector file types.
LightBurn can Import the following formats:
Vector / mixed formats:
  • .ai — Adobe Illustrator
  • .svg — Scalable Vector Graphics
  • .dxf — AutoCAD Drawing Exchange Format
  • .pdf — Adobe Portable Document Format
  • .plt / .hpgl — Plotter / Hewlett-Packard Graphics Language
Importing Text
If you import vector files not made in LightBurn that contain text, make sure that any fonts used in the file are installed on your computer, or that the text has been converted to paths using whatever tools are available in the other program. LightBurn is not able to import embedded fonts. If LightBurn is unable to import anything from your file, the status bar will display Nothing Imported.
Different programs use different terms for this process, but terms such as welding, convert to outline, and convert to path are common.
Importing GCode Files
Although LightBurn is able to import GCode files, it will only import the geometry saved within the file. Speed and power settings will not be imported, and filled shapes will be imported as the fill lines, not the outline of the shape.
Use caution with AI-generated files
If you use AI/LLM tools to generate files, please be aware that the files generated may not conform to standards for the file type you're importing and you may experience failed imports or unexpected results.
Image formats:
  • .png — Portable Network Graphics
  • .jpg / .jpeg — Joint Photographic Experts Group format
  • .bmp — Windows Bitmap
  • .gif — Graphics Interchange Format
  • .tif / .tiff — Tagged Image File Format
Quick Tip: Drag and drop directly into LightBurn
Importing .lbrn or .lbrn2 files
It is also possible to Import .lbrn or .lbrn2 files — however, Importing these types of files does not load the cut settings or any other project-specific information saved to the file. Only the graphics will be loaded.
In order to load graphics along with all other settings, you must use Open instead.
LightBurn will warn you if you attempt to Import a .lbrn or .lbrn2 file.
Click Open to load the graphics and all other settings, Import to load only the graphics, or Cancel to abort the process.
Import Warning
Export
Alt/Option+X
Exports currently selected graphics to your selected file format. If there is nothing in your current selection, the entire contents of your current project will be Exported.
Vector/Mixed Formats
The following formats are always available when exporting graphics:
Image Formats
The following formats are available only when you have a single image selected:
Exporting in one of these formats does not save cut settings or any other project-related settings.
Exporting an image does not include any image adjustments or image processing selections. To export an image including these adjustments, see Save Processed Bitmap.
