File List Window
Use the File List Window to browse and manage files stored on your laser's controller. This window is only available for users with DSP controllers that allow saving files to the controller.
Accessing the File List Window¶
If you have a DSP device profile selected, the File List Window is located in the upper right side of LightBurn, docked behind the Cuts / Layers Window, by default.
If you have closed the File List Window, go to Window → File List to re-enable it. To restore it and all other windows to their default positions, go to Window → Reset to Default Layout.
File List Window Options¶
Select File¶
Select a file from the list to enable all relevant buttons.
Refresh¶
Queries the DSP controller to update the list of files stored on the laser file system.
Start¶
Commands the laser to run the selected file.
Upload¶
Opens your system's file browser, where you can select and send any files previously saved to your computer in machine-specific format to the laser's controller.
Upload Current Project
Use the Send button in the Laser Window to upload the current project in the LightBurn Workspace.
Delete¶
Removes the selected file from the DSP controller file system.
Deleted files cannot be recovered.
Tip: Ruida Controllers
Start deleting from the bottom of the list. Starting from the top of the list may lead to extended file compaction time.
Calc Time¶
Press the Calc Time button to begin computing the job completion time for the selected file. The Calc Time button is available only on supported DSP controllers (Ruida). This can take a considerable amount of time for engraving jobs, as the controller is simulating the job through the onboard DSP microprocessor. Once complete, the calculated completion time will be shown in the Info column.
Delete All Files¶
Removes all files from the DSP controller file system.
