Clipboard Tools
The clipboard commands are tools for copying, inserting, removing, or duplicating objects in your Workspace, and transferring graphics into and out of LightBurn.
The clipboard commands are accessible in the Edit Menu, Main Toolbar, by hotkey, or by right-clicking in your Workspace to open a context menu.
Your computer's clipboard is a temporary storage location used to save items that you copy, so you can paste them to another location shortly after.
Copy
Ctrl/Cmd+C
Saves a copy of selected objects to your clipboard.
Cut
Ctrl/Cmd+X
Deletes selected objects in your Workspace while saving a copy of them to your clipboard at the same time.
Duplicate¶
Ctrl/Cmd+D
Creates copies of selected objects, directly on top of the existing objects.
Paste
Ctrl/Cmd+V
Inserts objects copied to your clipboard into your Workspace. Pasted objects are centered at the location of your cursor at the time of pasting.
Copy and paste from Adobe Illustrator
Some users have had trouble copying and pasting vector shapes from Adobe Illustrator. If vector shapes copied from Illustrator are being pasted into LightBurn as images rather than vectors, you may need to update your Illustrator settings.
In Illustrator, go to Illustrator → Settings → Clipboard Handling and make sure that On Copy: Include SVG Code is turned on. You can also export an SVG file from Illustrator and import it into LightBurn.
Drag and drop directly into LightBurn
You can copy text, vector graphics, and images from other design software, and paste them directly into your LightBurn Workspace.
Paste in Place¶
Alt/Option+V
Inserts objects copied to your clipboard into your Workspace and positions them according to their location in the project they were copied from.
Delete
Del
Deletes selected objects.
By default, LightBurn uses your system's clipboard. If you're experiencing slow performance when using the clipboard commands, disable Use System Clipboard in the Settings/Preferences window.
With this setting disabled, you'll no longer be able to copy and paste from other programs into LightBurn, or between LightBurn windows.
