Adding a Laser
The first time you open LightBurn, you'll be greeted by the Devices window, where you'll see an empty list, along with several options for creating a device profile at the bottom. You need to have at least one device profile created in order to use LightBurn, so if you close out of this window without creating one, you'll see a warning message with the option to go back and set up a device, have LightBurn automatically create a dummy profile for you, or close out of the software.
If your laser's manufacturer hasn't provided any special instructions or importable files, the quickest way to add a new laser to your list of devices is with the Find My Laser wizard. Follow the instructions below to use the wizard to set up your device.
If you don't have a laser yet, go to Create Manually to create a dummy profile as a placeholder until you get a laser.
Automatically Add a Laser to LightBurn¶
Make sure that your laser is powered on and connected by USB cable to a computer running LightBurn. Wait for the laser to complete any power-on moves, like homing, before continuing.
Click on the Devices button in the Laser Window, found in the lower right-hand corner of the program window by default, to open the Devices window.
If this is your first time running LightBurn, the Devices window will open automatically.
Click the Find My Laser button to launch the Device Discovery Wizard.
Click the Next button to begin scanning for connected devices.
A new window will open showing the progress of scanning for USB-connected devices.
The Device Discovery Wizard will display a list of recognized devices. Select your laser from the list and click Add Device.
Ruida: Packet vs. Serial
Some laser models will appear on the list twice, with two connection types, Packet/USB or Serial/USB. Serial/USB is the recommended option, while Packet/USB is an alternative option that does not work on all systems, but can sometimes improve file transfer problems.
If your laser wasn't found automatically, see Troubleshooting.
If you don't have a laser available to connect, you'll need to manually create a device profile.
Name your device, choose the units you want to use for this device, and confirm that the dimensions of the work area are correct.
Some lasers require additional information in order to complete the setup process. Continue below.
Additional Hardware-Specific Instructions¶
Click one of the options below to see instructions specific to your type of laser.
Not sure what type of laser you have? Head back to Identify Your Laser.
GCode Devices
GCode Devices¶
Set the machine origin. Nearly all GCode systems use the Front Left corner as the origin, regardless of where they home to. If you select the incorrect origin, your output will be flipped or mirrored — you can correct the origin later in Device Settings.
Enable Auto "home" your laser on startup if your machine has homing or limit switches, to automatically send your laser a homing command each time the device has been connected.
If your laser does not have homing switches, leave Auto-home off.
If you see Error: 9 in the Console Window later, it means you've enabled this feature but your machine is not equipped or configured for homing. You can disable Auto-Home later in Device Settings.
Select Next to continue.
Click OK in the Devices window to exit and save the new device profile.
Note for X-Carve and Shapeoko Users
Some GCode controllers used on X-Carve or Shapeoko devices may need specific configuration settings. If your device is not listed, click Other, and refer to manufacturer documentation for machine-specific parameters.
DSP Devices
DSP Devices¶
Set the machine origin. For DSP lasers, the machine's origin is the same as the location it homes to when it first starts up. If unsure, select the Rear Right corner, as most DSP controllers follow this convention. If you select the incorrect origin, your output will be flipped or mirrored — you can correct the origin later in Device Settings.
Galvo Devices
Galvo Devices¶
When adding a Galvo device, LightBurn will ask you to import the machine-specific configuration file from your EZCAD2 setup or installation drive. Navigate to the location it's saved and select the file to import crucial device settings. See Add a Galvo Laser for more information, including what to do if the configuration file is not available.
Video: Galvo Setup Guide
If LightBurn can't find your laser, it could be for a number of reasons:
- Missing drivers: Install your laser-specific drivers and software. Even if you don't plan to use their software, many device manufacturers include the necessary drivers that are not included with LightBurn.
- Ruida controllers use an FTDI driver available as part of the LightBurn installation process. Re-install LightBurn and select the box for the FTDI driver at the end of the process to install the driver — no LightBurn settings will be lost in the re-installation process.
- EZCAD2-based Galvo devices require a LightBurn-specific driver. Re-install LightBurn and select the box for the EZCAD2 driver at the end of the process to install the driver — no LightBurn settings will be lost in the re-installation process. See Galvo Driver Installation for more information.
- If you have a BSL Galvo laser, you may need to separately install a driver supplied by your machine's manufacturer, or install the stock software that came with your machine.
- Most diode lasers require the CH340 driver, available here.
- See Troubleshooting: Drivers for more information.
- Can't connect: Only one application can talk to your laser at a time. If you run other software, like RDWorks, Easel, Carbide Create, AutoLaser, or LaserCAD, make sure that software is not running when running LightBurn.
- Networked device: Network-connected lasers cannot be automatically connected. Follow the steps in Create Manually to set up your device.
- Marlin controller: Marlin controllers have a variety of baud rates and configuration options. They take significantly longer to reset than most other controllers, making them incompatible with Find My Laser. Follow the steps in Create Manually to set up your device.
